Aug 26, 2015 12:42 PM UTC
Middle Mouse Button Customization
I was wondering if it was possible to change the behavior of the MMB? Like to use Double click MMB for the Refit command or make MMB act the same as SHIFT+MMB, or any other sort of customization within Creo Parametric 2.0.
Aug 26, 2015 2:39 PM UTC
AFAIK
Only if you write a C Programm, catch the mouse input and push out the new one. There is no direct possibility to change it inside Creo.
Most mouse drivers also have no possibility for change MMB.
Br,
Eike
AFAIK
Br,
Eike
jcolon1-VisitorAuthor
Aug 26, 2015 4:10 PM UTC
This is what I suspected. I am trying to figure out how to write scripts to change it's behavior but was hoping there was an easier way.
Thank you!
