ploney
Apr 18, 2013 7:10 PM UTC
Multiple Points measurement output ?
Is there a technique that does not involve a toolkit to measure and output
X,Y,Z point data between multiple datum points
on a surface to one Coordinate Sys. ??
I am only able to select a single datum point with any Analysis measurement
tool.
Even using the CTRL-F Find menu it will only allow one datum point.
On M170 WF4 currently.
Thanks in advance.....
Peter J Loney
SAS IT Engineering Solutions
Intelligence, Information and Services
Raytheon Company
www.raytheon.com
Follow Raytheon On
LinkedIn
Raytheon Sustainability
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
