Need help to Update Text in Drawing Note using DetailText settext
Hello Everybody,
Right now I am trying to update existing text from Drawing note with another text using following hierarchy. But the text is not getting updated.
Can someone help me on this.
DetailNote
       -> DetailTextLines
                    -> DetailTextLine
                                 -> DetailTexts
                                           -> DetailText
                                                    -> SetText("Text")
Try to use
1. pfcDetail.DetailNoteItem.Erase
2. pfcDetail.DetailNoteItem.Modify
3. pfcDetail.DetailNoteItem.Show
Seshu Gudla
18-Opal
Hello @swapnildhengle,
What @YaroslavSin suggested should get you the expected result. Could you please try and confirm how it works for you ?
Try to use
Seshu
You have to modify DetailNote object, so the point is to set DetailTextLines. This is working for me:
Drawing drw = (Drawing) session.GetCurrentModel();
DetailItems items = drw.ListDetailItems(DetailType.DETAIL_NOTE, 1);
DetailNoteItem note = (DetailNoteItem) items.get(0);
DetailTextLines lines = note.GetTextLines(DetailTextDisplayOption.DISPMODE_NUMERIC);
DetailTexts texts = DetailTexts.create();
DetailText text = pfcDetail.DetailText_Create("Hello world");
texts.append(text);
lines.get(0).SetTexts(texts);
note.SetTextLines(lines);
Make sure you update the sheet to see changes.
Seshu Gudla
18-Opal
Hi Swapnildhengle,
Did the previous suggestions help ? Please let us know your current status on this Community thread, so we can continue to support.
Seshu
Seshu Gudla
18-Opal
Hi Swapnildhengle,
Could you please confirm if this issue is resolved or still pending ? if still pending we could engage further and work for a solution. Could you please update ?
Seshu
我提供一段批量替换的代码,供你参考
public void test23332(Session session){
try {
Drawing wd = (Drawing) session.GetCurrentModel();
DetailItems items = wd.ListDetailItems(DetailType.DETAIL_NOTE, 1);
for(int i = 0;i<items.getarraysize();i++){
WDetailNoteItem note = (WDetailNoteItem) items.get(i);
DetailNoteInstructions inst = note.GetInstructions(true);
DetailLeaders leaders = inst.GetLeader();
if(null != leaders.GetLeaders()) continue;//排除引用
DetailTextLines ss = inst.GetTextLines();
String strValue = "";
for(int j=0;j<ss.getarraysize();j++){
DetailTexts texts = ss.get(j).GetTexts();
for(int k = 0;k<texts.getarraysize();k++){
String value = texts.get(k).GetText();
strValue += value;
strValue += "\n";
String strInfo = i+ "\n" + ss.getarraysize() + "\n"
+strValue.trim();
JOptionPane.showMessageDialog(null, strInfo);
strValue = strValue.replaceAll("(?i)&cname", "&CMAT");
// strValue = strValue.replaceAll("&cname", "&CMAT");
// DetailTextLines textLines = PlaceNote.createDetailTextLines(wd,"wjt276\n产品名称: &cname".split("\n"),false,null);
DetailTextLines textLines = PlaceNote.createDetailTextLines(wd,strValue.split("\n"),false,null);
try {
note.SetTextLines(textLines);
} catch (Exception e) {
// JOptionPane.showMessageDialog(null, "出错:" + modelSub.GetFullName());
Wjt276UI.logError(e);
if(null != session.GetModelWindow(wd)){
wd.Regenerate();
wd.Save();
} catch (jxthrowable e) {
e.printStackTrace();
