Oct 10, 2014 3:09 PM UTC
Need help with Visual Basic routine in Excel to set locations in Creo Drawing
Hi, I've been working through the dark maze of the VBA API, and the documentation for running routines using the Excel VBA is as remarkably sparse. I am having difficulty trying to determine how to handle a CpfcPoint3D object in an Excel routine. I have VB examples; but, I'm unable to determine how to structure the same in Excel. Here is what I have in the Excel routine;
Dim location As CpfcPoint3D
Set location = New CpfcPoint3D
location.Set(0, 10.0)
location.Set(1, 10.0)
location.Set(2,0)
(Excel objects to the .Set method for a location array. But, this is the example for a VB routine)
This is an example from a VB routine (from the PTC VB API documentation);
Dim pointLoc As IpfcPoint3D
pointLoc = New CpfcPoint3D
pointLoc.Set(0, 200.0)
pointLoc.Set(1, 600.0)
pointLoc.Set(2, 0.0)
Is there any VB API guru that can tell me what I'm doing wrong with my own code?
Thx!
