8-Gravel
Dec 14, 2023 7:36 AM UTC
Net Speed and Creo 7.0 macro running relation with Windchill database
I am Dnyaneshwar Maid and working as Sr. CAD Engineer in Miba Engineering Center, Pune Maharashtra State, India. We are using Creo 7.0 along with Windchill PLM Version 12.1.2.0 database system.
In this year we have developed some macro/batch files for customization under Tools>>Auxiliary Applications>> option. These all customized batch files we have kept on common server which is located  in Europe so that we all (Indian and European or USA Colleagues) can use these batch files whenever needed.
Now we are facing issue and these batch file's are not getting started in India and coming message that unable run the batch file.  When we contacted to developer he is saying that due low internet speed (low band width) these files are not getting run as these files are running from common server as mentioned above. We are having net speed of 200 Mbps and still developer saying to increase it to run batch files smoothly.
I want to ask you all if anyone come across such a similar issue ? Does 200 Mbps internet speed is really less for running batch files from common server along with Windchill database? Please suggest solution on this issue.
Dnyaneshwar Maid
Dec 15, 2023 10:37 AM UTC
Try to set Windows environment variable (default value is 60. Set bigger value)
PROTK_DELAYINIT_STARTUP_TIMEOUT=120
Also check, but not sure that this variables steal working in current version of the Creo
PROTK_DELAYINIT_NO_DELAY
PROTK_DELAYINIT_ALWAYS_INIT
