Jan 21, 2014 5:16 PM UTC
New to J-Link
Hi all,
I am new user going to learn PRO-TOOLKIT, can somebody help me to get Good source of tutorials
jkparthiban
Jan 21, 2014 6:02 PM UTC
same as this http://portal.ptcuser.org/p/fo/st/thread=54199&post=122468#p122468
br,
Eike
Jan 22, 2014 5:50 AM UTC
Thank you Friend
I found that help docs in my installation directory
jkparthiban
Jan 26, 2014 6:04 PM UTC
In Reply to Eike Petersen:
br,
Eike
Hi Mr.Eike
I tried from using that docs, I have error with "application failed to start" , I dont know where I am doing Mistake, Please Help me for my starting.... May you send protk.dat file & class file for any simple example?
Thank you
jkparthiban
Jan 27, 2014 8:55 AM UTC
protk.dat
NAME Test
STARTUP dll
EXEC_FILE D:\temp\WF4Test\test.dll
TEXT_DIR D:\temp\WF4Test\text
ALLOW_STOP true
DELAY_START false
END
I didn't have a short program, but I'm sure there are very short "Hello World" examples inside the Creo directory for Toolkit. Often someone forgets to add the toolkit license to the startup Licenses inside his Creo license declaration (setup -> extended license stuff -> add Toolkit to your startup license and restart Creo : ) ).
Also you need the right Visual Studio (I have heard about many cross compilings from other ones) to build the right DLLs. PTC supports exact one Visual Studio per Creo // ProE Version. So its 2005 WF4, 2008 WF5, 2010 Creo 2 I think, but I've not be sure if the WF5 one is right.
Best regards,
Eike
