Sep 5, 2015 1:18 AM UTC
No write access C:\\Windows\systems32\
I'm very new to the Creo Program.  After installing the program and getting the student licensing, I am having trouble loading the parts from the Creo Parametric 2.0 tutorial DVD into the program itself.  When running the DVD, I get a script error. I've saved the tutorial files to my hard drive, but when the Creo Parametric program loads, I get - No write access C:\\Windows\system32\.
Any advice to troubleshoot?
Sep 7, 2015 8:36 AM UTC
Hi Joe,
Please submit your issue by using "Academic Support Request":
Academic Case Logger
PTC Academic Program | Academic Technical Support | PTC
Mahesh_Sharma
22-Sapphire I
Sep 7, 2015 1:37 PM UTC
Joe,
You can submit a case for TS as suggested by Vladmir however prior that try changing the startin directory for Creo:
Select Creo Shortcut > Right Click > Properties
Change Startin directory to Documents folder.
Mahesh_Sharma
22-Sapphire I
Sep 28, 2015 6:21 PM UTC
Joe,
Any update on this post which you can share here?
