Feb 7, 2017 9:23 AM UTC
Object toolkit
How to create a sequence of costum elements such a ProArray ?
Feb 7, 2017 10:50 AM UTC
Like this:
  ProWstring *w_array;
  status = ProArrayAlloc(0, sizeof(ProWstring), 1, (ProArray*)&w_array);
#include <ProArray.h>
ProErrorProArrayAlloc(
int n_objs
/* (In)
The initial number of objects allocated in the array.
int obj_size
/* (In)
The size of each object in the array
int reallocation_size
/* (In)
The minimum number of objects added or deleted if Creo Parametric TOOLKIT resizes the array, e.g. on a call to ProArrayObjectAdd.
ProArray* p_array
/* (Out)
The allocated array
After that you can add elements by:
  status = ProArrayObjectAdd(w_array, PRO_VALUE_UNUSED, 1, p_object );
Don't forget to free it at the end of the life cycle.
  status = ProArrayFree((ProArray*)&w_array);
Br,
Eike
Feb 7, 2017 1:26 PM UTC
Thank for you answer. but I want do the reverse.
How to create a sequence of custom objects of my class  ?
Feb 7, 2017 1:43 PM UTC
easiest way is to use std. c++ ways like vectors, maps, such kind of stuff : )
If you need it as a "Creo like" way I don't know ^.^ I was never in need of that.
But I think you can use an xanysequence. As alternative you can use xlongsequence and fill it with pointers to the objects you have allocated. So I'm not so sure about the size, if it didn't fit for pointers you could use xrealsequence, cause xreal is defined as a "real C++" double, that should be 8Byte --> 64 Bit and so same size as your pointer.
Br,
Eike
