Jul 3, 2015 2:03 PM UTC
Opening Multiple files
Hi, i would like to know how to open multiple files by copying the file names from an excel or notepad?
    Jul 6, 2015 9:24 AM UTC
    Use VB and VB API to Creo.
    Should work.
    Chris3
    Jul 6, 2015 11:38 AM UTC
    Alternatively, if you don't know one of the toolkits, record a mapkey of opening one file and then copy paste it over and over into one large mapkey only changing the file input line. You can also create a script in the programming language of your choice to generate that mapkey for you.
    If you do this, you will need to rmake sure all of the lines have a \ at the end, except for the last line. The mapkey will stop on the last line that does not have the \
    Jul 8, 2015 7:00 PM UTC
    If you are using J-Link to open, only you create a method that reads the values of the notepad and then open.
    File file = new File("C:\temp\read.txt");
    FileReader fileReader = new FileReader(file);
    BufferedReader reader = new BufferedReader(fileReader);
    String data = null;
    while((data = reader.readLine()) != null){
         codigo = data;
    fileReader.close();
    reader.close();
    To open Creo do as follows:
    //for parts
    ModelType mdl_type = ModelType.MDL_PART;
    //for assembly
    ModelType mdl_type = ModelType.MDL_ASSEMBLY;
    ModelDescriptor proeModelDescriptor = pfcModel.ModelDescriptor_Create(mdl_type, codigo, null);
    proeModel = session.RetrieveModel(proeModelDescriptor);
    proeModel.Display();
    I hope I have helped!
    Jul 14, 2015 8:46 AM UTC
    Hi
    nm-2
    It is possible using ProToolKit Customization and it is already developed in our organization.
    Please reach us.
    Jul 14, 2015 8:51 PM UTC
    All solutions require some programming, building an trail file may be the easiest one .
    If you don't want to take the time, try using this script: ---
    Jose
