2-Explorer
May 28, 2018 3:25 AM UTC
Optimization using protoolkit
Hello
We would like to run optimization/feasibility (In part mode, Analysis --> Optimization/Feasibility) using pro toolkit.
Could not find any API for the same. Is there a way to achieve the same through automation?
Thanks and Regards
Ketan
2-Explorer
May 30, 2018 7:12 AM UTC
We are open for any of the automation method and not restricted to toolkit only. Any suggestion would be of great help.
May 30, 2018 7:21 AM UTC
Hi Khetan
Did you try with a mapkey?
if the mapkey is viable for you then you could try calling the mapkey from toolkit.
2-Explorer
May 30, 2018 7:32 AM UTC
thank you for your response. Mapkey is the solution but there is a concern in case of mapkey running through toolkit.
As it is executed at last, we wont be able to show result in different formats on GUI through toolkit with mapkey usage for optimization run.
