Dec 23, 2020 11:50 AM UTC
Orient flat state on a drawing
Hi
I need to have the flat state placed flat on the drawing, for the lasercutter.
Is there a way to do this?
I'm thinking, create a saved orientation and use this on the drawing.
I doesn't matter how the part is oriented, just it is flat.
Allan
Dec 23, 2020 12:18 PM UTC
I have made a short video showing you how you can use flat states in a drawing.
It is attached to this message.
Hopefully this is what you are looking for.
akok12-AmethystAuthor
Dec 23, 2020 1:24 PM UTC
Thank you.
My problem is, I will like to automate the process you showed.
I will like the get Jlink to first make the flat, here after put the flat on the drawing on sheet 2, orientated flat in 1:1 scale.
My problem is I don't know how to orient it flat.
Allan
Dec 23, 2020 3:02 PM UTC
I can not help you with doing that using JLink, but can't you do it using a mapkey?
