May 20, 2016 12:25 AM UTC
OtkTestInstall does not works
Hello every body. I'm trying to make the "OtkTestInsta" work. I've got build the otktestinstall sucssesfully, but a erro message apears when PTC creo starts. The trial.log shows:
!trail file version No. 1800
!Creo  TM  3.0  (c) 2016 by PTC Inc.  All Rights Reserved.
!Exit Logger data:
! Process ID: 9332
! Application: Creo_Parametric
! Start date&time: 2016/05/17  21:51:12
! language: portuguese
! machine type: x86e_win64
! datecode: M010
! Server: NONE
! Workspace: NONE
! traceback file: C:\Users\Public\Documents\traceback.log
!end Exit Logger data.
< 0 0.846222 1220 0 0 714 1366 0 0 768 13
!mem_use INCREASE Blocks 614322, AppSize 60831821, SysSize 72386376
< 0 0.669630 1109 0 0 565 1366 0 0 768 13
< 0 0.669630 1054 0 0 565 1366 0 0 768 13
!%CIWelcome to PTC Creo Parametric 3.0.
!Application (pt_inst_test): running DLL-mode user_initialize
!%CD
!Application (pt_inst_test): returned from DLL-mode user_initialize; status is 0
!Application (pt_inst_test): started via registry.
! exec path: C:\Users\Public\Documents\makeinstall\make_install\pt_inst_test.dll
! type: synchronous Pro/TOOLKIT DLL
! Message Dialog: Warning
!               : Foreign program "protoolkit" failed to initialize: error PRO_TK_GENERAL_ERROR
~ Activate `UI Message Dialog` `ok`
!               : Startup of application "protoolkit" failed.
~ Close `main_dlg_cur` `main_dlg_cur`
!Command ProCmdOSExit was pushed from the software.
!               : PTC Creo Parametric will terminate and any unsaved work will be lost.
!               : Do you really want to exit?
~ FocusIn `UI Message Dialog` `yes`
~ Activate `UI Message Dialog` `yes`
!Application (pt_inst_test): running DLL-mode user_terminate
!Application (pt_inst_test): returned from DLL-mode user_terminate
!End of Trail File
The example in "C", makeinstall Works fine.
Does anybody can help me?
Thanks!!
Ariovaldo
