Output feature points data
Hello,.I have problem,
I want to use toolkit get points data from pattern,how can I do?
Thanks and Regards
Roger
Hi
if you want to get it from pattern head:
// feat could be from a selection
pfcFeature_ptr feat = pfcFeature::cast(selectionItem);
if (feat->getFeatType() == pfcFeatureType::pfcFEATTYPE_PATTERN_HEAD) {
	pfcFeaturePattern_ptr featpat = feat->GetPattern();
	if (featpat != NULL) {
		pfcFeatures_ptr feats = featpat->ListMembers();
		if (feats != NULL) {
			for (int j = 0; j < feats->getarraysize(); j++) {
				pfcFeatureType type = feats->get(j)->GetFeatType();
				if (type == pfcFeatureType::pfcFEATTYPE_DATUM_POINT) {
					pfcSelection_ptr sel = pfcCreateModelItemSelection(pfcModelItem::cast(feats->get(j)));
 // do whatever you want with your element
					data->ref_references->append(sel);
Br,
Eike
CAD_Roger1-VisitorAuthor
hello,Eike
Can I use this method to export .txt file?
You can use it for everything with points. So it just get the pattern in and the points (inside of selections) out. So you could get the points out of the selections and then get the position out of the points.
You need to decide to which Coordinate system you want to recalculate the position (to be sure that it also work in Assemblies and if your main CS is not the Part root CS).
So in simplicity yes. That's what I do with these sniplet 🙂
Br,
Eike
FV_01
December 17, 2019
search for a function ProUtilGeomitemDump in pt_examples UtilGeom.c, copy/paste code for PRO_POINT.
As Eike mentioned,
use ProPatternMembers get to get a ProArray of point features
use ProFeatureGeomitemGet to get ProGeomitem which is going to be a PRO_POINT
the rest is from pt_examples
do not forget to apply appropriate transformations.
HIH.
FV.
