Parametric startscript toolkit usage
I have a parametric startscript and i it is creating a creotk.dat for the toolkit usage.
Now i have a second toolkit which iam writing in the creotk.dat.
Now i have the problem that i cant start the second one. It is loading in it but cant start with the message in german:
Initialisierung des fremdsprachigen Programms "Name" fehlgeschlagen: Fehler PRO_TK_GENERAL_ERROR.
I wrote the text also in the creotk.dat which already exists.
Environment variable PRO_COMM_MSG_EXE is already implemented.
How can say in my startscript (Powershell) that he has to implement it to parametric?
I guess i have found the problem.
One Toolkit is looking for a Enviornment.
The Environment was setted but i dont know where.
The Path of the other toolkit was wrong.
But it works actually.
1. Leave only one - second app in .dat file. Test if the app is workable.
2. The app is Java (.jar) or C/C++ (.dll)? Java app can need some extra dependence in option "java_app_classpath" in .dat file.
3. If possible, show a content from your dat file
I can use the toolkit if i activate it manually.
But i noticed that there is a line in Parametric with the notice: Basis-Lizenz Toolkit ist nicht verfügbar.
Iam sorry but its not possible.
I suppose, the tookit app is not unlocked.
Do you are the author of this app?
