Pattern Table Toolkit
Is it possible to import datum points  in Creo model  stored  in .pts format file using Creo Toolkit C++ Programming.
Which functions and libraries can be used to import it.
TIA.
tbraxton
Creates a new object representing the PTS file from which to create an import feature.
Class wfcIntfPTS (ptc.com)
Thank You for your reply.
Do we need to use object toolkit only for this or this can be achieved using protoolkit C++ programming.
tbraxton
The function call I posted is from this subsection of the help files: The Creo Object TOOLKIT C++ APIWizard (ptc.com)
