Sep 20, 2019 6:51 AM UTC
please help me in this regard
Can anyone share me the C++ code to convert Drawing files into PDF Using Visual Studio 2015?
    Sep 23, 2019 6:37 PM UTC
    It depends if you are using Pro/Toolkit or Object Toolkit.
    For Pro/Toolkit you should use ProPDFExport API. For Object Toolkit have a look at pfcPDFExportInstructions and pfcPDFOptions classes.
    18-Opal
    Sep 26, 2019 8:47 AM UTC
    If you are using C / C ++ TOOLKIT
    You can find the C / C ++ TOOLKIT example code in article CS61272.
    https://www.ptc.com/ko/support/article?n=CS61272&language=en&posno=5&q=toolkit%20export%20pdf&source=search
