Possible VB.Net webpage using VB API to connect to Pro/E?
- 2 replies
- 1022 views
- Translate All
All,
I have created a simple VB.Net webpage using VB API on my pc's desktop. It runs fine on the desktop and successfully grabs and displays the current working directory of my Pro/E session. When I move this page to the network, it cannot establish a connection to Pro/E. When I move this off of my computer, I assume the path to the pfclscom.exe is lost (set through environment variable on my pc). Is there a way to specify this path so that a vb.net webpage can connect to Pro/E?
The goal here is to create a webpage rather than a console app in order to allow easier maintenance. I want to avoid having to use the embedded browser in Pro, so weblink is not a good option. Attached you will find the code I am using that works when run on my computer but not from the network.
Can this be done?
Corey
