Apr 17, 2016 2:02 PM UTC
Post CL file using VB.NET
            hi all,
        Is there any function to post the cl file using VB.NET
as a work around solution I have create the mapkey  , this mapkey work fine within the CREO , but when running thru vb.net I get following error ' Illegal characters in input. Re-enter:"
vb.net code below..
          mapkey1 = " mapkey pp @MAPKEY_LABELpostprocessor;~ Command `ProCmdMfgPostFile` ;\"
            mapkey1 = mapkey1 & "mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;\"
            mapkey1 = mapkey1 & "mapkey(continued) ~ Update `file_open` `Inputname` `op010`;\"
            mapkey1 = mapkey1 & "mapkey(continued) ~ Command `ProFileSelPushOpen@context_dlg_open_cmd` ;#DONE;#UNCL01.P02;\"
            mapkey1 = mapkey1 & "mapkey(continued) ~ Activate `texttool` `CloseButton`;"
            mfg_session.RunMacro(mapkey1)
Apr 20, 2016 1:44 PM UTC
You are right. The culprit is the "\" character at the end of the lines.
Try:
mapkey1 = " ~ Command `ProCmdMfgPostFile` ;"
mapkey1 = mapkey1 & "~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;"
mapkey1 = mapkey1 & "~ Update `file_open` `Inputname` `op010`;"
mapkey1 = mapkey1 & "~ Command `ProFileSelPushOpen@context_dlg_open_cmd` ;#DONE;#UNCL01.P02;"
mapkey1 = mapkey1 & "~ Activate `texttool` `CloseButton`;"
Apr 18, 2016 1:30 PM UTC
According to VB API documentation:
The method pfcSession.BaseSession.RunMacro runs a macro string. A VB API macro string is equivalent to a Creo Parametric mapkey minus the key sequence and the mapkey name.
Based on this your mapkey1 string should look like this:
          mapkey1 = " ~ Command `ProCmdMfgPostFile` ;\"
            mapkey1 = mapkey1 & "~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;\"
            mapkey1 = mapkey1 & "~ Update `file_open` `Inputname` `op010`;\"
            mapkey1 = mapkey1 & "~ Command `ProFileSelPushOpen@context_dlg_open_cmd` ;#DONE;#UNCL01.P02;\"
pesau-21-VisitorAuthor
Apr 19, 2016 4:27 PM UTC
hi,
I tried the code, I get the same error message
Try:
Apr 20, 2016 8:34 AM UTC
Print the finished mapkey1 to a textbox, textfile or whatever and compare the string character by character to the original mapkey.
Probably just a missing character, additional whitespace or something of that nature..
Apr 21, 2016 5:28 AM UTC
hi all
Thanks for you support,
Now the code is working fine after removing the  '"\"
