7-Bedrock
Oct 11, 2023 3:12 PM UTC
Print drawing in PNG format
Hi i'm Andrea
I'm using Creo 7.0.2.0, i would like to export my drawing in an immagine in png format (without the background).
I know it's possible to export in jpg and tiff format, but i haven't found the png format.
Can someone help me, please?
thankyou
best regards
Oct 12, 2023 11:56 AM UTC
KenFarley
Oct 11, 2023 4:20 PM UTC
I've used a lot of drawings in documents where I needed a .png file to import. My method is like this:
(1) Output drawing to PDF. Make sure to set color setting to Monochrome, and I use 600 DPI for resolution.
(2) Read that PDF file into an image editor. I use GIMP (it's free and does nice things). Be sure to tell it to import at 600 DPI or whatever you choose as your preferred resolution.
(3) Image should be just black and white. Make sure the drawing editor is set up to use transparency.
(4) Select by color, choosing the white background. Then delete it. You should only have the lines and other black contents.
(5) Export this as a .png.
It's not the most convenient method, but it works really well. Plus, with the image editor, I can clean up any things I don't like before outputting (customer name info, etc.)
7-Bedrock
Oct 12, 2023 7:01 AM UTC
KenFarley thankyou for your reply
now i'm using the same process, but I thought there was a quicker or integrated solution.
KenFarley
Oct 12, 2023 10:29 AM UTC
Yeah, the only png output in the drawing is "snapshot" which is pretty useless, I think.
Oct 12, 2023 11:55 AM UTC
maybe you can use something like https://www.win2pdf.com/doc/print-to-png.html
