Oct 9, 2014 5:38 PM UTC
Printing from specific paper trays
I have an HP CM2320 printer with 3 paper trays. Is there a way to use a .pcf file to specify the tray to print from. We use specific colored sheets for different things and it would be nice to set up map keys that would print using different .pcf files that would select the tray with the desired paper. I thought there would be a command line option I could add to the line "plotter_command".
My .pcf file currently looks like this:
plotter LASERJET4
button_name HP LASERJET Printer
button_help HP LASERJET Printer
plot_drawing_format YES default
plot_segmented NO default
plot_roll_media NO default
plot_label NO default
plot_handshake software default
create_separate_files NO default
plot_with_panzoom NO default
rotate_plotting NO default
allow_file_naming NO
plot_name YES
plot_translate -0.130000 0.000000 default
interface_quality 3 default
plot_scale PLOT 0.930000 default
plot_destination printer default
plotter_command windows_print_manager \\W7SFIPROE02\HP CM2320 Printer
pen_table_file C:\PTC\user_local_proew5_pdm\table.pnt
plot_sheets current default
paper_size A4 default
paper_outline NO default
plot_clip NO default
plot_area NO default
2-Explorer
Oct 9, 2014 5:44 PM UTC
At the least you'll need to find what commands the printer to use different trays. I suspect those will be appended to the plotter_command entry.
2-Explorer
Oct 9, 2014 9:50 PM UTC
OK - because HP makes everything harder than it needs to be.
http://www.experts-exchange.com/Hardware/Peripherals/Printers_Scanners/Q_23762465.html
Suggests that creating a .reg file of the printer settings and then loading it for a workable solution. That might be the better solution as it doesn't seem to require as much poking to get it to work OK. The best thing is that there is only one level of software trying to control the printer.
This may also help. It covers the PCL and PJL commands that are used to control the printer.
http://www.piclist.com/techref/language/pcl/index.htm
Tray selection is shown in the http://www.piclist.com/techref/language/pcl/decoded.htm list. The list links to http://www.piclist.com/techref/language/pcl/source.htm
At the worst, consider getting 2 more printers. They don't cost very much and they can be named for the color paper they have, for what that's worth.
Oct 9, 2014 7:50 PM UTC
We just went through this exercise with a Ricoh plotter. In our case, we were sending HGPL output but needed to prefix it with something to specify a different tray than the plotter was defaulting to. It turned out the Ricoh doesn't use PCL but something else. In any case, we finally got the commands needed and injected that into the beginning of the output file.
However, I'm not sure how you'd do that by using the windows_print_manager and content within the .pcl file. Perhaps as David says, you can just append the commands to the plotter_command entry. In our case, we created a reference file with the appropriate header information and then used something like "copy /b <header file>+%1 <printer>". This takes the plotter command information (in the header file), merges the output plot file (%1) with it, and sends it directly to the desired printer (e.g. \\W7SFIPROE02\HP CM2320 Printer).
Frankly my experience, including recent experience dealing with performance as we batch print some manufacturing drawings right now, is the old-school "copy /b" is more efficient than windows_print_manager. Your results may vary.
Oct 10, 2014 5:32 AM UTC
Greg,
if it is not possible to use solution mentioned by Daniel Reid and if you have some programming knowledge, then you can use AutoIt. This tool enables you to program user selections and clicks done manually when user prints a drawing using MS Printer Manager. AutoIt produced exe-file, that you can launch using Creo mapkey.
Martin Hanak
