May 4, 2017 8:51 PM UTC
Printing help (Creo 3)
We have an older E-size printer - the HP DesignJet T1200, but it's still kicking.
One of the problems is that the prints we send to it turn out in grayscale.
Does anyone know what settings to use so that they turn out in color?
I tried using plotters POSTSCRIPT, DESIGNJET600, COLORPOSTSC, all do the same monochrome output.
Maybe I have to go through the MS print manager?  The PDFs I print from Acrobat Reader on this printer do come out in color, so that might be it...
Anyway, this is the PCF file:
! Pro/Engineer Plotter Configuration File
PLOTTER DesignJet
BUTTON_NAME C - HP DesignJet T1200(XYZP0006)
BUTTON_HELP Front Office - near entrance
PLOTTER_COMMAND print /d:\\XYZfileserver3\XYZP0006
PEN_TABLE_FILE C:\PTC-Apps\Plotter\pnt\hpdj_t1200.pnt
PAPER_SIZE C
PLOT_SCALE fit_paper
PLOT_WITH_PANZOOM no
PLOT_NAMES yes
ALLOW_FILE_NAMING yes
DELETE_AFTER_PLOTTING yes
PLOT_TRANSLATE 1.000000 0.500000 default
and this is the pnt file:
pen 1 thickness .015 IN; edge_highlite_color attention_color section_color;
pen 2 thickness .008 IN;
pen 3 thickness .008 IN;
pen 4 thickness .012 IN;
pen 5 thickness .012 IN;
pen 6 pattern 1 IN ; thickness .012 IN;
pen 7 pattern .06 .06 .06 .06 IN;thickness .009 IN;
pen 8 thickness .010 IN;
is there a config.pro setting that I'm missing?
many thanks in advance for you print gurus.
TomU
TomUAnswer
May 4, 2017 9:16 PM UTC
By the way, I don't know for sure if the "DesignJet" plotter output is Postscript, but I know for sure that POSTSCRIPT and COLORPOSTSC are.  Obviously to see color you would need to use the COLORPOSTSC one.  If the COLORPOSTSC works then there is possible that the "DesignJet" outputs black and white or the plotter will only accept black and white.
TomU
May 4, 2017 8:57 PM UTC
To test whether the issue is Creo or the printer, print to a file, rename as .ps, then use Adobe Acrobat Distiller (need the licensed version of Acrobat) to convert this to a PDF.  If the PDF is in color, the issue is the plotter.  If the PDF is black and white then you know the issue is with Creo.
psobejko1-VisitorAuthor
May 4, 2017 9:03 PM UTC
I don't have Acrobat Distiller, but will try out your diagnostic method with ghostview.
TomU
May 4, 2017 9:14 PM UTC
Feel free to upload one here.  I'm more than willing to convert it.
May 5, 2017 1:59 PM UTC
DesignJet plotter set in your pcf file is BW plotter. I manually selected DESIGNJET650C to produce plot file. As you can see in a4.plt.doc (copy of a4.plt contents), PC1 HPGL-2 command sets RGB colors for individual lines.
See attachment.
MH
May 5, 2017 2:00 PM UTC
Note: During printing into file, I unchecked pentable option.
