Apr 11, 2011 9:29 PM UTC
Pro/E / Pro/Intralink Connection Error
Hello All,
I have a Pro/E / Pro/Intralink launch problem that I have not been able to find a solution for.
We currently use Pro/E WF2, M190 with Pro/Intralink 3.3, M021 for production.
We are planning moving to WF5 M060 and PDMLink 9.1 in a couple of months.
WF2 was working perfectly until a couple of months ago when I loaded WF5 and began testing it as well.
Now, every time I launch Pro/E WF2 from Intralink linked to a workspace (Intralink-Launch Pro/ENGINEER-Workspace-xxxx) on my machine I get the following error message:
"Pro/INTRALINK connection error -Pro/INTRALINK launch command not specified."
I select cancel and can work in Pro/E and it is linked to the workspace and I can work ok in Pro/E, but it is affecting my J-Link apps in that the session will no longer connect to an async J-Link app.
If I launch Pro/E on a colleague's workstation I do not get the error, but I cannot use that machine full time.
Initially I did not have a different cache directory specified for WF2 and WF5 in the startup batch file but now do.
A tech support call to PTCwas unable to find a solution.
Any advice would be greatfully received.
TIA
Paul Stephens
Kenworth Trucks Australia
