Mar 29, 2018 2:38 PM UTC
Pro/Library: Issue with setting up catalog - SPACES IN FILE NAME LOCATION
Good day --
I am trying to set up and configure a test environment to install some of the old libraries.
One specific issue I am encountering is setting up the configuration to run properly.
Here is one specific example:
- Run the connector library set up
- Install the files
- RUN \connlib\bin\i486_nt\mkconnconfig.exe
- ENTER PATH for Library Loadpoint Directory
  - Filename contains spaces
  - ERROR: X:\XXXX - invalid directory
I have tried using "" 's and double "" 's when inputting the location. Same results each time.
Any suggestions would be greatly appreciated.
Thanks in advance.
Aaron Spicer
