18-Opal
Pro_Mdl_name Retrieve ISSUE getting error PRO_TK_E_NOT_FOUND.
When ProMdlnameRetrieve gets PRO_MDLFILE_DRAWING, depending on the environment, it takes a long time to get a return value other than PRO_TK_NO_ERROR.
For example, in the case of PRO_TK_E_NOT_FOUND, if the PDM server is not active, the return result of ProMdlnameRetrieve takes less than 1 second.
If the PDM server is enabled, it may take up to 2 minutes to return PRO_TK_E_NOT_FOUND.
If anyone has had a similar issue to me, can anyone share a solution?
Warm Regards
SeonHo.CHA
