18-Opal
Pro/PROGRAM Graphical Editor
Repost from Part Modeling...
Just wanted to let you all know... the latest release of Nitro-PROGRAM has a NO HASSLE - FREE LICENSE option...
If you have ever struggled with seemingly never ending edit-import-fix-import-fix-import cycle of creating or editing Pro/PROGRAMs for Creo Parametric Parts or Assemblies... -OR- nearly screamed while trying to edit a Pro/PROGRAM that someone else created....
Then Nitro-PROGRAM is something you should download immediately and use!
Nitro-PROGRAM eliminates the pains and frustrations of the "text editor" and transforms the creating, editing and testing of Pro/PROGRAMs into a visual, drag-and-drop, editing love-fest by comparison.  😉
Nitro-PROGRAM saves time, reduces frustration, improves accuracy and enables you to think about the most important elements of Creo Parametric Automation -- data-flow and regeneration!
Simply Download, Unzip, Run.... and request a FREE License... NO REGISTRATION REQUIRED!
Nitro-PROGRAM does require JLINK to be installed with Creo Parametric.  (instructions here if you need them)
The only difference between FREE and a Purchased License is the amount of content you can import changes for.
Most companies, the FREE License will be extremely useful.
Enjoy!
Dave
HamsterNL
HamsterNLAnswer
18-Opal
From my own experience (testing Nitro-PROGRAM):
You can open any part/assembly which contain PRO/Program. Nitro-PROGRAM will display your PRO/Program nicely is its graphical editor. There's no limit in "extracting" the PRO/Program from your model into Nitro-PROGRAM.
The free version is limited on the number of IF statements it can import back into your model.
The current limit is only 5 IF statements for the free version (but IF statements in the Relations do not count to this limit).
If you hit the limit, the free version of Nitro-PROGRAM will simply not import the (modified) PRO/Program back into the model. It will show a splashscreen (see below) and a message "Exceeded free-license limits on imported IF statements" in the Log View of Nitro-PROGRAM.
Hello, @DavidBigelow
Thanks for sharing!
Please, check UTF support. Feature names in the tree and relations.
18-Opal
Language?!
can you send a model to test?!
dave
Language: Russian
please can you reveal the exact limits implemented in the FREE version ?
My questions follow:
1.] How many features can a part have?
2.] How many features+components can an assembly have?
3.] What happens when the limit is exceeded?
HamsterNL
HamsterNL18-OpalAnswer
18-Opal
@DavidBigelow ,
please can you confirm this "definition" of limited functionality for Nitro-PROGRAM application using FREE license ?
... AND ... please can you add "definition" of limited functionality for Nitro-BOM application using FREE license (in separate discussion) ?
