Aug 20, 2014 8:14 AM UTC
Pro toolkit
Hello All,
After registering Auxiliary application in Creo 2.0 when I click on Start button it give me an error
"Creo registry file protk.dat : appliation failed to start"
I have correctly kept path for Text Folder and dll file location in protk.dat file.
Any help greatly appreciated....Thanks....
Aug 26, 2014 3:55 PM UTC
Hey Chirag,
This typically is related to your code. Do you have your user_initialize() and user_terminate() functions defined properly? Also, are you using an Asyncronous or Syncronous environment? I typically use the following format for syncronous DLLs:
extern "C" {
int user_initialize();
int main(int argc, char *argv[]);
void user_terminate();
// Initialize Toolkit Environment
ProToolkitMain (argc, argv); // Syncronous
return 0;
// Do some stuff
return(0);
return ;
Sully
cshah1-VisitorAuthor
Aug 27, 2014 8:26 AM UTC
Hello Sully,
Thanks for your reply.
I have defined user_initialize() and user_terminate() functions properly.
I am using Syncronous environment.
Can you please give me your Email Id so that I can share it with you.
Chirag Shah
Jul 7, 2017 5:14 AM UTC
Hi
Do you've properly set your Environmental Variables?
