18-Opal
Jun 7, 2018 1:30 AM UTC
Problem displaying LNK2019 when using external library
I want to use an external library to handle Excel in the toolkit.
xllib is the library I want to use.
Added xllib.h as header.
Next, you tried to set the link in the project properties.
However, since the configuration type of the toolkit is makefile, there is no link setup option!
How should we solve this problem?
Jun 7, 2018 3:40 AM UTC
Try cerating normal project instead of makefile.
Easily you can resolve linking errors.
CHASEONHO18-OpalAuthor
18-Opal
Jun 12, 2018 9:37 AM UTC
The build succeeds but the toolkit application does not start.
Jun 12, 2018 10:17 AM UTC
You are able unlock DLL\EXE ?
