Aug 2, 2012 11:06 AM UTC
Problem while start ProTK dll on another PC
I have written a small tool in Visual Studio 2005 for Wildfire 4. On my pc it work like a charme. On the other pc (also Windows 7 Professional 64 bit, Wildfire 4 M200 - 64 bit, same Hardware) it don't work. The only Failure I get is that Pro Engineer can't start the Application. (it is not the "file not found" error) The other PC has no Visual Studio 2005 installed.
The other PC has a Pro Toolkit License too. I have installed the Visual Studio 2005 redistributable package (64bit). Nothing happens. Have anyone an idea what I can do to solve this problem?
Best regards,
Eike
DomenicLaritz
Aug 2, 2012 11:12 AM UTC
In Reply to Eike Petersen:
Best regards,
Eike
And what's the exact error message, you get?
Regards, Domenic
Aug 2, 2012 11:35 AM UTC
Thx to Ronald Tellen who has written me an E-Mail :
shortened Content : Try to install .Net 2.0
I have installed it and it didn't helped, but thx for the answer.
With a DLL - Dependency Walker I get on the PC on that it isn't work (Side by Side configuration error)
To Domenic:
The complete Failure is in german, because my Wildfire version is in german, I try to translate it:
The ProToolkit program "Model Processor" can't be started. Please look inside the Trailfie to get more informations.
After click ok in this window a second one appear.
Inside the Trailfile only the Failure message appears a second time.
Best regards,
Eike
Aug 2, 2012 11:49 AM UTC
Are you sure your exec_file and text_dir lines in the protk.dat file are correct?
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110
[cid:image001.jpg@01CD7083.633B9BD0]
Aug 2, 2012 12:06 PM UTC
Hi Eike,
Be sure to compile your executable in Release mode. If it is compiled in
Debug mode, it will expect the full MS VS Debugger to be available and I
would expect the exact error you are seeing.
Ben
DomenicLaritz
Aug 2, 2012 12:18 PM UTC
I'm German speaking too. 🙂
Back to the problem ... because you're using Windows 7 x64, I assume, you've installed the Service Pack 1 of Visual C++ 2005?! Otherwise Visual C++ won't run.
If you look at the platform notes of Pro/TOOLKIT for Pro/E Wildfire 4.0 (http://www.ptc.com/WCMS/files/53026/en/ProTOOLKITPlatformsWildfire40.pdf) you'll see that SP1 is not supported for the 64-bit platform. This is because of a bug in Visual C++ 2005 SP1.
When we migrated to Windows 7, we installed Visual C++ 2008 as development environment. And till now we haven't had any problems with it.
Regards, Domenic
Aug 2, 2012 2:43 PM UTC
Thx at all for helping.
I found a solution for my problem.
My DLL was Mutli threaded DLL (in Properties -> C / C++ -> General) and I changed it to Multi Threaded.
After that I need to let the Linker know (Properties -> Linker -> Input -> Ignore Specific Library = libcmt.lib)
After that my build dll don't need other DLLs and I don't have the problem I've had before.
Best regards,
Eike
