Aug 10, 2015 2:10 PM UTC
Problem with Java Toolkit application and Creo Parameteric 2.0 M170
Just installed Creo Parametric 2.0 M170 and two of my Java Toolkit applications won't start anymore.
Haven't had any problems with these applications in all earlier build codes of Creo Parametric 2.0.
I used the same installation xml files as always. Installation includes JRE.
Anybody see the same?
My system has Java 7 Update 51 and Java 6 Update 45 (both 32-bit and 64-bit)
ocorten-2Answer
Aug 11, 2015 10:02 AM UTC
Since Creo Parametric 2.0 M170 I need to specifically point Creo to Java although JRE is included in the install.
I now copy the JRE folder to a location without the buildcode in the path and then point to it with the config.pro option.
ocorten-212-AmethystAuthorAnswer
