Dec 21, 2020 10:36 AM UTC
problem with jlink OnCommand method.
Hi folks,
I'm new to j-link. Could somebody explain what is wrong in my code?? why OnCommand method doesn't show message window??
thx in advance for all help.
Dec 21, 2020 12:57 PM UTC
@Gucio wrote:
Hi folks,
my suggestion ... ask PTC Support.
Gucio16-PearlAuthor
Dec 21, 2020 1:44 PM UTC
Martin,
It's good that you are in good mood.
PTC support is not to give an answer for "how to do it" -it is the last mail that I've received 😞
Regards
Dec 21, 2020 4:17 PM UTC
@Gucio wrote:
Martin,
Regards
I am sorry I do not understand the meaning of your reply.
Note:
If you need to get some help, you have to provide:
  • complete copy of your project (source code file, pictures, additional files, protk.dat)
  • information about Creo version you use
  • information about JDK version you use + method how you compile your application
  • information about JRE version you use in combination with Creo
Feb 18, 2021 8:59 AM UTC
Method SetIcon() accepts only image file name. Actual image file must be located in the text directory under resource directory. See documentation:
IconFileName—Specify the name of the icon file, including the extension. A valid format for the icon file is the PTC-proprietary format used by Creo .BIF, .GIF, .JPG, or .PNG. The new pane is displayed with the icon image. If you specify the value as NULL, the default Creo icon is used. The default search paths for finding the icons are: ○ \\Common Files\text\ resource ○ \resource ○ \\resource The location of the application text directory is specified in the registry file
