ProDtlattachAlloc() and note leader referencing an axis on a drawing
- 2 replies
- 1188 views
- Translate All
I have a question regarding 2D notes with attachment to an axis. I am talking about drawing notes - not 3D annotations!
See attached screenshot.
I am able to create a note with a leader attachment to a point or an axis.
My problem: The attachment to the axis cannot be easily modified by the user after creation. When you create this type of note with Pro/E manually, you are able to move the leader along the axis by simply dragging the attachment point. The notes/leaders created with Toolkit can be modified only byusing the command"modify attach" on the note.
Does anyone of you has ever done this?
What I already tried:
With PRO_DTLATTACHTYPE_OFFSET my Attachpoint is the leader attach point in screen coords (z==0) and Selection contains the view, the item selection and the UV parameter==0.5 to attache the leader to the center of the axis:
ProDtlattachAlloc (PRO_DTLATTACHTYPE_OFFSET, NULL, AttachPoint, Selection, &hLeaderAttachment);
With PRO_DTLATTACHTYPE_PARAMETRIC my selection contains the view, the point coords AND the UV parameter:
ProDtlattachAlloc (PRO_DTLATTACHTYPE_PARAMETRIC, NULL, NULL, Selection, &hLeaderAttachment);
Thanks for any tips,
Andreas
__________________________________
Andreas Hellmann
MCAD Services Pro/E & Pro/E customization
Am Wartfeld 7
D-61169 Friedberg
phone: +49 151 21259910
mail: -
