7-Bedrock
Jun 19, 2017 5:01 AM UTC
ProMdl object should get erased correctly even without returning control to Creo UI.
--In Pro/Toolkit code, if I erase ProMdl object and do not pass control to Creo UI then it will not get erased.
--Please see attached small code for demonstrating an issue.
Jun 19, 2017 6:32 AM UTC
did you report the "problem" to PTC Support ? What did they say ?
MH
