ProParameterWithUnitsCreate returning PRO_TK_BAD_INPUTS
Hello Community,
I am using ProParameterWithUnitsCreate, on Creo 9.0.2.0,to add a parameter to a model. However, everything I have tried to make it work has failed.
The code I am using is below:
ProParamvalueSet(&testVal, p_value, new_value_type);
err= ProParameterWithUnitsCreate(&target_item, test, &testVal, NULL, &testInit);
target_item is a valid ProModelItem, test is a valid wchar_t*, testval is a valid ProParamValue, and testInit is an unitialized ProParameter. I have followed TestParams.c file to check if I did anything wrong, but it appears I have not.
I have also looked at this article, Article - CS383949 - Creo Parametric Toolkit API ProParameterWithUnitsCreate() fails with error PRO_TK_BAD_INPUTS on specific machine (ptc.com), but it is unclear to me what registry file I am supposed to change the unicode_encoding to True on.
Does anyone have any idea as to why, with valid inputs, I am receiving the PRO_TK_BAD_INPUTS error?
Mark Hardebeck
RPN
RPNAnswer
18-Opal
Check your protk.dat/creotk.dat
ProParameterWithUnitsCreate() fails with error PRO_TK_BAD_INPUTS on specific machine.
Caused by unicode_encoding set to False in the registry file
Resolution: Remove the registry key unicode_encoding (or) set its value to True
RPN
18-Opal
The model item must have a name, if this is true, you may need to provide more code 😉
TestNewParam(ProMdl target_model){
ProError NoConv;
ProModelitem  target_item;
ProParameter testInit ;
ProParamvalue testVal;
ProParamvalueType new_value_type = PRO_PARAM_STRING;
void* p_value;
wchar_t test[120];
char testc[120] = "Param";
NoConv = ProMdlToModelitem (target_model,&target_item);
if(NoConv != PRO_TK_NO_ERROR)return(-1);
ProStringToWstring(test,testc);
p_value = (void*)(wchar_t*)L"Include params";
NoConv = ProParameterWithUnitsCreate(&target_item, test, &testVal, NULL, &testInit);
RPN
18-Opal
This is a simple example from PTC.
ProDrawing drawing;
 ProModelitem model_item;
 ProParamvalue param_value;
 ProParameter parameter;
 status = ProMdlCurrentGet(&drawing);
 status = ProMdlToModelitem(drawing, &model_item);
 param_value.type = PRO_PARAM_DOUBLE;
 param_value.value.d_val = 10.0;
 status = ProParameterWithUnitsCreate(&model_item, L"test", &param_value,NULL, &parameter);
For a string value use s_val, and copy using ProStringToWstring and PRO_PARAM_STRING for the type. For the Param name, same procedure.
Instead of „drawing“ use your ProModel (or Mdl :-))  „model“, same code, makes no different.
If this works, check the functions of ProParamvalue* and use them.
There are a lot of examples if you have toolkit installed.
