Jan 29, 2014 1:22 PM UTC
ProRibbonDefinitionfileLoad() in Creo2
Hello!
I am checking the possibilities we have for UI (ribbon) customization with TOOLKIT...
First of all: With Creo 2 M090 I don't get the *.rbn file anymore when saving my customization (done manually in Creo). But it is possible to rename the automatically saved *.uito *.rbn andafter copying thisto the <appdir>\text dir as toolkitribbonui.rbn it is loaded when launching Creo the next time; the app has to be started of course...
With ProRibbonDefinitionfileLoad(L"myribbonname.rbn") it is possible to load a *.rbn with a name different from "toolkitribbonui.rbn". This works for me if myribbonname.rbn is located in <appdir>\text\ribbon.
Now my final question:
Does anyone know if the ProRibbonDefinitionfileLoad() can be called only once??? The answerseems to be "YES".My intention is to load multiple *.rbn to be able to customize Creo's UI more or less completely by Toolkit. For some users I want to display tab1 and tab2, for some other users only tab2 and tab3...
Any experience with that? I am on Creo2 M090.
Andreas
__________________________________
Andreas Hellmann
MCAD Services Pro/E & Pro/E customization
Am Wartfeld 7
D-61169 Friedberg
phone: +49 151 21259910
Jan 29, 2014 4:42 PM UTC
Andreas,
This is from my experience with J-Link.
You will probably have to create a .rbn for each possible combination.
Tab1_tab2.rbn
Tab2_tab3.rbn
Tab1_tab3.rbn.
Lots of files if you have many combinations.
I have added all general tabs in my master ui file. Then I only need to load the applications specific ui from each application. This way I am not bounded by a launch sequence.
You can update icons and message on the fly, which could by another way of achieving the same result.
When changing icons I need to minimize/maximize the ribbon before the graphics updates. This is done with a macro sequence as J-Link has no methods for this.
/Bjarne
