Sep 12, 2013 4:44 PM UTC
ProSelect() and silhouette edge
Good evening,
does anyone know how to use ProSelect() to let the user select a cylinder's silhouette edge on a drawing?
Imy application the user should be able to select two points on solidgeometry - then I create a broken view with ProDrawingViewBrokenVisibleAreaSet(). If I pass "point" or "axis" as filter string (first argument) to ProSelect() everything works fine. I want the user to be able to select a solid edge - that works if we are talking about a "sharp" edge. I cannot select a silhouette edge with Toolkit. Is that right? Or is there some sort of "hidden" filter available for ProSelect()?
Any experiences with this???
Andreas
__________________________________
Andreas Hellmann
MCAD Services Pro/E & Pro/E customization
Am Wartfeld 7
D-61169 Friedberg
phone: +49 151 21259910
mail: -
Sep 13, 2013 11:25 AM UTC
Andreas,
I'm not exactly sure what you mean by silhouette edge. Can you post a screenshot?
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image001.jpg@01CEB052.7AE88A30]
Sep 16, 2013 7:55 AM UTC
I have attached a picture with a screenshot for selecting a silhouette edge/surface.
And I want the user to be able to select this type of edge/surface...
Andreas
Andreas Hellmann
Am Wartfeld 7
D-61169 Friedberg
mail: -
6-Contributor
Sep 13, 2020 11:52 AM UTC
Hello sir,did you solved this problem? I am encounterring this problem too
