Apr 21, 2017 7:07 PM UTC
ProServerRegister in Creo3 Toolkit Issue
Recompiling a WF5/CEpro5.o toolkit program to Creo 3.   The particular program runs as an unmanned batch system.   The program registers Windchill in the User_Initialize function.  Now that I compile the code to Creo3 I just get a flashing window when the ProServerRegister command is used.  Its the exact same as the issue reported in the unresolved CS246648 - which shows a video of the behavior.   Their example is slightly different because a user is clicking a button to initialize the toolkit registration, but same thing.
  Is anyone in any version of Creo3 able to perform a ProServerRegister?    If so whats your datecode?
  This code has worked for years.
tkerr = ProBrowserAuthenticate(username, password);   returns 0  no error.
tkerr=ProServerRegister(serverAlias, codebaseURL, WINWName, &aliased_url);
msteffkeAnswer
Jul 7, 2017 12:32 PM UTC
I end up with a fix for this.  PTC notified me it was fixed in Creo 3.0 m120.   Not just running in m120, but I had to recompile as well. It at least stopped the flickering window.  It appeared to work but would only connect to the last used workspace regardless of which workspace I specified and ProServerRegister would return a -5 (found).  To solve that issue i have included a line in my startup file to rename the .svr_mgr_db3.fldx file (WC cache file that contains your past windchill connection info).  ProServerRegister now will register any specified workspace.
Apr 22, 2017 4:24 PM UTC
Hello Mark
  What is the compiler version you've used? CREO 3 Supports Visual C++ 2012 (VS 2012 Compiler).
I Don't have CREO 3 but in CREO 2 ProRegisterServer() working fine for me.
I am using Visual C++ 2010 compiled DLL into Visual Studio 2015 C# Project (Creo 2 Supports Visual C++ 2010 Compiler only)
msteffke15-MoonstoneAuthor
Jul 6, 2017 7:07 PM UTC
I am using the VS 2012 compiler.
 Issue still not solved. still an spr at PTC.
Jul 7, 2017 4:36 AM UTC
Hi @msteffke
I have some bad experiance on same code works in C Programming (.c) files yet it  not works on C++ Programming (.cpp). You may try with c. This may not a solution but a suggestion
msteffke15-MoonstoneAuthorAnswer
Nov 7, 2017 11:33 AM UTC
Hi Mark,
was it solved in M120? I just recompiled a Creo2 toolkit program in Creo 3 M140 and the flickering window pops up.
Kind regards,
Jan
Nov 7, 2017 3:39 PM UTC
In my opinion it is not fixed.   I never could get it to hook to any workspace other than the last WS.  ProServerRegister would return a -5 (found).  To solve that issue i have included a line in my startup file to rename the .svr_mgr_db3.fldx file (WC cache file that contains your past windchill connection info).  ProServerRegister now registers any specified workspace.  Its  a workaround, but I had to move on to other things.
The line I used in my proe1.bat file is:
RENAME %PTC_WF_ROOT%\.SSAPPD\ServerMgr\.srv_mgr_db3.fldx old.srv_mgr_db3.renamed
