8-Gravel
Jan 14, 2026 12:51 PM UTC
ProSimprepdataitemsVisit returns bad items for replaced components
Hello PTC Community
I am using Creo Parametric Release 10.0 and Datecode10.0.8.0
I need to get the simplified representation used as substitution of an item of a dedicated simplified representation of an assembly. So I'm using ProSimprepdataitemsVisit to get the items and filtering them on the action type. it works well with a new created simplified representation.
After replacing the a component having a substitution by a component having also same replied representation name, it is not possible to get it : the previous component is still return as ProSimprepitem ( its item_path still have the previous CID).
How to update the simplified representation item?
    RPN
    18-Opal
    Jan 22, 2026 10:21 AM UTC
    Sorry but I have difficulties to understand your topic.
    After replacing the component you get the same model handle as before replacing?
    Did you try to regenerate the assembly?
    But again I did not really understand your topic.
    It is a simplified rep, you need to get the representation for  the path. Only for an interchange this is different.
    Maybe a textual example?
