ProTool OTK_Install
- 3 replies
- 4200 views
- Translate All
I am following the OTK_Cxx_GSG pdf documentation to test the ProTool Installation in my computer. Unfortunately, I don't understand the last step.
13. Run PTC Creo Parametric or PTC Creo Direct from the otk_install_app
directory that contains the prodev.dat file. The PTC Creo Object
TOOLKIT C++ application adds the command OTK Install Test on the Home
tab, in the OTK group, on the PTC Creo ribbon user interface.
what does that mean?
Also, is there a template out there that sets up all the necessary dependency to write a C++ project for PTC?
I have included the pdf file in this post.
