2-Explorer
May 3, 2016 12:19 PM UTC
ProXsecCompXhatchGet()
Could anyone will be able to let me know what need to be passed for argument "int id" for toolkit API ProXsecCompXhatchGet()?
We are using Creo 2.0 M090.
Thanks and Regards
Ketan
May 3, 2016 3:09 PM UTC
Took a look at the code.  'id' is a bit of a misnomer here.  What is wanted is the index in the array returned by ProXsecGeometryCollect.
2-Explorer
May 3, 2016 7:22 PM UTC
Thank you for your help on this...
I am based out of India and hence, I could not check what you have suggested...
If I am not wrong, I presume ProXsecGeomCollect would give me array. While API for Hatch get require only integer as argument.
Could you please help me to know what to be taken from array returned from ProXsecGeomCollect API? I.e. what is the logic to be considered for taking index from array.
Thanks in advance.
Regards
Ketan
May 3, 2016 7:32 PM UTC
Index in an array is the position of the desired item in the array (starting at 0).  If you call ProXsecGeometryCollect(xsec, view, &geom_arr) and you get geom_arr with size 3, you have three ProXsecGeometry structures, indices 0, 1, and 2.  If you look at the first one, and find its memb_id_tab is the component you are interested in changing the hatching of, you would pass 0 as the id.  If it is the next one, you would pass 1, and so on.
