Apr 10, 2012 5:53 PM UTC
pt_examples Requires 3D Drawings License?
I am trying to compile the pt_examples application and when I try to run it (with the Pro/TOOLKIT license attached to Pro/ENGINEER) I get an error message stating that the application was not unlocked and it requires the Pro/TOOLKIT for 3D Drawings license. Has anyone else experienced this with Pro/ENGINEER WF 5.0 M070 x64?
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110
[cid:image001.jpg@01CD1721.5D91D390]
Apr 10, 2012 6:10 PM UTC
Hi Patrick,
Which examples are you trying to run.
Many of the ProAnnotation* & ProDimension* functions need that license.
pt_dbase folder has some such function calls.
If you search API references for "Pro/Toolkit for 3D Drawings" you will get
a list of all functions that need this license.
Vinay
Apr 10, 2012 6:13 PM UTC
Thanks Vinay. As of now I just used the one that came with the Pro/TOOLKIT installation so I don't need to compile it again. However I do think that this is a gap where customers must have a 3D Drawing license just to compile the example application... Is it possible to just compile 1?
[cid:image002.jpg@01CD1724.2B520730]
Apr 10, 2012 6:26 PM UTC
Hi Patrick,
In the makefile make_examples, just keep the objs you want.
For e.g. to build just pt_main & pt_feats I would keep the following. I
think pt_utils is needed in several so I will keep that too.
# Object files
OBJS = pt_main.obj pt_feats.obj pt_utils.obj pt_utils1.obj
If I remember correctly that is all we need to do.
Vinay
