18-Opal
Aug 21, 2018 12:28 AM UTC
Questions about ProMacroLoad performance
Questions about ProMacroLoad performance.
If you use ProMacroLoad more than a certain number of times, the performance of Creo seems to be degraded.
Also, it seems that ProMacroLoad does not work when used more than a certain number of times.
I can not be certain about this situation.
I can not be sure of all the commands used in the previous ProMacroLoad.
I just used the code to update all of the drawing files in a particular directory the other day.
I used ProMacroLoad (`ProCmdViewRegenAll`) instead of API when updating.
Only 256 out of 300 succeeded.
The performance of Creo also slowed shortly thereafter.
Does anyone know anything about ProMacroLoad that fails and degrades Creo performance?
I think it's safe to call ProMacroLoad 50 times in a single function.
I'm curious about your opinion.
Warm Regards,
SeonHo
