read function Pattern table
I am trying to read a ptb file into pattern table using toolkit. I only find one way to do so is to read the ptb file and then build the element tree and assign the values into the element tree.
Is there any other way it can be done or any sample code to refer how to build element tree of pattern table.
Thank You
Catalina
Community Manager
Hi @Sss4598,
Thank you for your question!
Best regards,
Catalina | PTC Community Manager
