6-Contributor
Read/write parameters on dimensions
I am using Creo Parametric 4.0 M140
I am trying to read and apply parameters on an annotation, specifically a driven dimension in a 3d model (PRO_DIMENSION or pfcITEM_DIMENSION). When I create a parameter on the modelitem, the parameter gets applied to the .prt that owns the dimension. How do I set a parameter on the actual dimension? What modelitem associated with the dimension owns the parameters? I can access these parameters manually by selecting parameters in the right click menu of the dimension so there must be a way of doing this programmatically.
HI @srosell,
Can you please tell me what are you trying to achieve by associating a parameter to the driving dimension?
Do you want the dimension to be controlled using a parameter?
Let me know your end requirement. I think i will be able to help you then.
Deepak
srosell6-ContributorAuthor
6-Contributor
I have created a custom Modelcheck that reports on overwritten dimensions. There are a few instances where an overwritten dimension is valid so I want the user to have the ability to ignore a found overwritten dimension so it does not pop up in future Modelchecks. My thought was I would add a parameter to the dimension that would mark it as ignored. The problem I'm running into though is that i cant seem to apply a parameter to the dimension modelitem.
FV_01
instead of attaching a parameter to a dimension make a string parameter to hold dimension id's to ignore, make id's comma-delimited. your checks would be as simple as checking for a substring within a main string.
