Sep 14, 2010 11:22 AM UTC
Reading 3D sketch using Protoolkit
We have functionality to write text in sketcher mode.Is anybody aware of API support to get & set this text?
Dec 21, 2018 12:07 PM UTC
I have the same question.
Any ideas will be helpful.
Dec 29, 2018 9:08 AM UTC
I found a way to create new text in a scketch
ProError SketchedTextReplace (ProFeature *feat, ProName refdestext)
	ProError status;
	ProSection section;
	ProIntlist ent_ids;
	int n_ids;
	Pro2dEntdef *p_ent;
	Pro2dTextdef *mytext;
	ProElement featElemTree;
	ProElement sketcherElem;
	ProElempath sketcherElemPath;
	status = ProFeatureElemtreeExtract(feat, NULL, PRO_FEAT_EXTRACT_NO_OPTS, &featElemTree);
	//Get section
	ProElempathItem sketcherElemPathItem[2] = {
		{PRO_ELEM_PATH_ITEM_TYPE_ID, PRO_E_STD_SECTION},
		{PRO_ELEM_PATH_ITEM_TYPE_ID, PRO_E_SKETCHER}};
	status = ProElempathAlloc(&sketcherElemPath);
	status = ProElempathDataSet(sketcherElemPath, sketcherElemPathItem, 2);
	status = ProElemtreeElementGet(featElemTree, sketcherElemPath, &sketcherElem);
	if (status != PRO_TK_NO_ERROR) //Not a section
		return status;
	status = ProElementSpecialvalueGet(sketcherElem, NULL, (ProAppData*) &section);
	status = ProSectionIntentManagerModeSet(section, PRO_B_TRUE);
	status = ProSectionEntityIdsGet(section, &ent_ids, &n_ids);
	for (int i=0; i<n_ids; i++)
		status = ProSectionEntityGet(section, ent_ids[i], (Pro2dEntdef**)&mytext);
		if (mytext->type == PRO_2D_TEXT)
			Pro2dTextdef newtext;
			int newtext_id;
			ProWSecerror sec_errs;
 //copy parameters from old text
			newtext.type = mytext->type;
			newtext.first_corner[0] = mytext->first_corner[0];
			newtext.first_corner[1] = mytext->first_corner[1];
			newtext.second_corner[0] = mytext->second_corner[0];
			newtext.second_corner[1] = mytext->second_corner[1];
			status = ProWstringCopy(mytext->font_name, newtext.font_name, PRO_VALUE_UNUSED);
			status = ProWstringCopy(refdestext, newtext.string, PRO_VALUE_UNUSED);
			status = ProSectionEntityAdd (section, (Pro2dEntdef*)&newtext, &newtext_id);
			status = ProSectionEntityDelete (section, ent_ids[i]);
			status = ProSecerrorAlloc (&sec_errs);
			int n_errors;
			status = ProSectionRegenerate (section, &sec_errs);
			status = ProSectionIntentManagerModeSet(section, PRO_B_FALSE);
			status = ProSecerrorFree (&sec_errs);
			//Redefine feature
			ProFeatureCreateOptions *featCreationOpts = NULL;
			status = ProArrayAlloc(1, sizeof(ProFeatureCreateOptions), 1, reinterpret_cast<ProArray *>(&featCreationOpts));
			featCreationOpts[0] = PRO_FEAT_CR_NO_OPTS;
			ProErrorlist errorList;
			status = ProFeatureWithoptionsRedefine(NULL, feat, featElemTree, featCreationOpts, PRO_REGEN_NO_FLAGS, &errorList);
			ProArrayFree ((ProArray*)&featCreationOpts);
			return status;
		}//if
	}//for
	return PRO_TK_E_NOT_FOUND;
