Aug 31, 2021 8:06 AM UTC
RegenerateRelation is not updating relation value using VB api code
I am using Creo Parametric 2.0 M250
RegenerateRelation api is not modifying relation value in creo2 using VB code
Here are the errors that I faced
pfcExceptions::XToolkitGeneralError
at pfcls.IpfcRelationOwner.RegenerateRelations()
at customApp.modInit.changeDateFromRelation(IpfcModel iObjModel, String strToProcess)
    Seshu Gudla
    18-Opal
    Aug 31, 2021 12:03 PM UTC
    @SK_9994711  Please make sure that the relations you are writing in the model are valid and do not have any errors. Try writing the exact same relations manually from UI and see if there are any errors. On which Object you are calling RegenerateRelations() ? is it a feature or the model ? Share your code snippet and a sample model if possible.
    Seshu Gudla
    18-Opal
    Sep 2, 2021 8:58 AM UTC
    The relation change made and appended to the model was successful. There were a couple of evaluation errors present in the model which was resulting in warning message "warning Probable error in function evaluation". Due to this, RegenerateRelation() was throwing exception pfcExceptions::XToolkitGeneralError.
    RegenerateRelation() was successful as expected when there were no relation errors or evaluation warnings present in the model relations.
    -Seshu
