Nov 3, 2015 4:22 PM UTC
Remove interference material (Cut) during or after mechanism
I am running a mechanism of essentially a gear shape. I would like to male tooth to cut out the female section as a result of the motion I have defined.
These aren't really gears but a special profile and would like to analyze what the female side should be so nothing interferes while they are rolling.
Thanks!
Steve C
Nov 4, 2015 8:41 AM UTC
If you're in Mechanism, I believe this can be done using motion envelopes.
Sorry I can't help more, but hopefully that might lead you to some useful searches...
