7-Bedrock
Jun 28, 2019 3:51 PM UTC
REMOVING UNUSED DRAWING MODELS
I need to remove all unused drawing models.
And I don't know if this is possible to do it with a macro or something like that.
can help me somebody?
Thank you,
Alberto Todisco
Jul 1, 2019 3:34 AM UTC
You can do this with ModelCHECK
7-Bedrock
Jul 1, 2019 12:26 PM UTC
Can you explain me the process?
Jul 2, 2019 3:54 AM UTC
you need to set UNUSED_MODELS check to Y or E in your .mch file.
This works only if you have enabled ModelCHECK.
Jul 2, 2019 8:51 PM UTC
Hi Alberto
If you don't use Modelcheck, but you are working with Windchill, you could use this creo config option:
cleanup_drawing_dependencies=yes_cs_not_required
More info in this Article
7-Bedrock
Jul 3, 2019 10:21 AM UTC
Hi Trebla,
that's the better solution!! thank you so much
RPN
18-Opal
Jul 26, 2019 11:15 PM UTC
# p-Shell
# „ps_draw delete“ will return 1 on success and 0 if fail
# if your case you may not interested
# and the code is ignoring the return value
# sample A
# if your active window contains a Drawing
foreach M [ps_draw list] {ps_draw -mod $M del }
# sample B
# # for all drawings in session
foreach D [ps_glob *.drw] { foreach M [ps_draw -draw $D list] {
ps_draw -draw $D -model $M delete
# sample c
# # for test.drw
# foreach M [ps_draw -draw test.drw list] {
ps_draw -mod $M -draw test.drw delete
Jul 29, 2019 5:50 AM UTC
please provide more information about p-Shell.
RPN
18-Opal
Jul 29, 2019 8:44 AM UTC
Link to p-Shell Wiki, and there a YouTube Link. Its a Toolkit Application, which allows you to access Creo Files and their Database via Tcl (Script Language) commands within a running Tcl/Tk environment. On the Wiki you find a lot of code snippets. You are ready with your first program in p-Shell, before you would have setup Toolkit and the compiler on the other hand Smiley Very Happy
