Nov 28, 2018 6:21 AM UTC
Retrieve constraint of component by toolkit
Hi All,
Kindly suggest how to retrieve constraint of a component in assembly by toolkit
regards,
MS
RPN
18-Opal
Nov 30, 2018 11:31 AM UTC
You should consider to start here:
ProAsmcompConstraintsGet (ProAsmcomp *component,ProAsmcompconstraint **pp_constraints );
Read ProAsmcomp.h
Have fun 🤔
Manjunath1-VisitorAuthor
Dec 1, 2018 3:17 AM UTC
Hi RPN,
I used the following code
	ProError err;
	ProMdl mdl;
	ProSelection* sel;
	int count;
	ProAsmcomp* cmp;
	ProAsmcompconstraint* constr;
	err = ProMdlCurrentGet(&mdl);
	err = ProSelect("membfeat",1,NULL,NULL,NULL,NULL,&sel,&count);
	err = ProSelectionModelitemGet(sel[0],(ProModelitem *)cmp);
	err = ProAsmcompConstraintsGet(cmp,&constr);
	return err;
but I could not retrieve the constraints
Manjunath S
RPN
18-Opal
Dec 1, 2018 10:46 AM UTC
Sorry, I’m not at my desk, but As far I remember the selection option is invalid. Because  you will get a PRO_FEATURE and not a PRO_PART or PRO_ASSEMBLY
Input Arguments:
     component       - The assembly component
Component Feature membfeat PRO_FEATURE
Assemble component model component PRO_PART, PRO_ASSEMBLY
Try this
err = ProSelect("component",1,NULL,NULL,NULL,NULL,&sel,&count);
Component and Feature ID are the same, you can also set the model item type to PRO_PART or PRO_ASSEMBLY manually in your code, after you have selected the feature, and extracted the model item. But this is the purpose of the „component“ option.
