Dec 18, 2024 7:42 PM UTC
Retrieve model
I retrieve model with ProMdlnameretrieve but I am not able to display it using toolkit.
I used ProMdlDisplay but still it does not work it stays in active session but do not get displayed in window.
What should I do?
Dec 18, 2024 8:10 PM UTC
Ive done this several ways, i will paste a couple samples here.  Looks like Im still using the deprecated function but it should function the same.
In this case i create and set a window current, then retrieve then display.
ProWindowCurrentGet(&WindowId0);
        ProObjectwindowCreate(windowname, PRO_MDL_ASSEMBLY, &WindowId1);
ProWindowCurrentSet(WindowId1);
        tkerr = ProMdlRetrieve (name, PRO_MDL_ASSEMBLY, &mdlUnitDrawing);
        if (tkerr == PRO_TK_NO_ERROR)
ProMdlDisplay(mdlUnitDrawing);
            ProWindowActivate(WindowId1);
In this case, the model was retieved, then a window created and set current, then Promdldisplay was used:
tkerr = ProMdlRetrieve(modelName2, PRO_MDL_DRAWING, &mdlDrawing);
fprintf(fp, "retr %d\n", tkerr);
tkerr = ProObjectwindowCreate(modelName, PRO_MDL_DRAWING, &WinId);
fprintf(fp, "ob win %d\n", tkerr);
tkerr = ProWindowCurrentSet(WinId);
fprintf(fp, "win cur set %d\n", tkerr);
tkerr = ProMdlDisplay(mdlDrawing);
This code below is something I got from the user guide examples.
 /* Retrieve an object */
 if (err == PRO_TK_NO_ERROR && ret > 0)
	ProStringToWstring(w_name_type, name);
 	err = ProMdlnameRetrieve (w_name_type, type, &model);
 	TEST_CALL_REPORT("ProMdlnameRetrieve ()",
 "UserRestartProeTest()", err, err !=PRO_TK_NO_ERROR);
 /* Display the object */
 err = ProObjectwindowMdlnameCreate(w_name_type, (ProType)type, &w_id);
	TEST_CALL_REPORT("ProObjectwindowCreate()",
 err = ProMdlDisplay(model);
	TEST_CALL_REPORT("ProMdlDisplay()",
Jan 7, 2025 9:01 AM UTC
Hello, I am able to retrieve model but it does not display in window. The model stays in session. How can I display it?
