8-Gravel
Jul 15, 2024 8:29 AM UTC
RetrieveSymbolDefItem Interface need using demo
Version:Creo Parametric 5.0.6.0 OTK C++
Description: I tried a lot of combination of using RetrieveSymbolDefItem method but they seems don't get the right object.For example I'm using it like this :
pfcDetailSymbolDefItem_ptr pDefSymDefItem = pOwner->RetrieveSymbolDefItem("circlerevice.sym", pfcDTLSYMDEF_SRC_PATH);
Of course my pro_symbol_dir  is set and the symbol I want to retrieve("circlerevice.sym") is in the directory.I've tried add fullfilepath and change pfcDTLSYMDEF_SRC_PATH to pfcDTLSYMDEF_SRC_SYSTEM along with move symbol file from user defined dir to system symbol dir but the method still doesn't work.Can somebody help me?Thanks a lot. I think it would be better if those API document come with same demo code.
Jul 16, 2024 8:38 PM UTC
Yeah, sample code on these classes and stuff would be VERY nice.  I'm not as familiar with the C++ side, but I'll share my code from weblink/js.  I tried to just include the relevant bits, so apologies if I'm missing anything.
 var session = pfcGetProESession ();
 var drawing = session.CurrentModel;
 var dwgView = seledge.SelView2D;
 var stop = false;
 var point;
 while (!stop)
 var mouse = session.UIGetNextMousePick (pfcCreate ("pfcMouseButton").MouseButton_nil);
 if (mouse.SelectedButton == pfcCreate ("pfcMouseButton").MOUSE_BTN_LEFT)
 point = mouse.Position;
 stop = true;
 else
 stop = true;
 var position = pfcCreate ("pfcFreeAttachment").Create (point);
 position.View = dwgView;
var symDef = drawing.RetrieveSymbolDefinition ("flagnote_hex", null, null, true);
var Hexinstrs = pfcCreate ("pfcDetailSymbolInstInstructions").Create (symDef);
Hexinstrs.ScaledHeight = 8.25;
Hexinstrs.SetGroups(pfcCreate("pfcDetailSymbolGroupOption").DETAIL_SYMBOL_GROUP_ALL , null);
var notenum = flagnote
var varText = pfcCreate ("pfcDetailVariantText").Create("NUM" , notenum);
var varTexts = pfcCreate("pfcDetailVariantTexts");
varTexts.Append(varText);
Hexinstrs.TextValues = varTexts;
var Hexposition = pfcCreate ("pfcFreeAttachment").Create (point);
var HexallAttachments = pfcCreate ("pfcDetailLeaders").Create ();
HexallAttachments.ItemAttachment = Hexposition;
Hexinstrs.InstAttachment = HexallAttachments;
var symInst = drawing.CreateDetailItem (Hexinstrs);
symInst.Show();
 var stop = false;
 var point;
 while (!stop)
 stop = true;
 else
 stop = true;
symInst.Show();
8-Gravel
Aug 14, 2024 7:36 AM UTC
This line would be instruction of my question.Any way,Thank you very much!
Community Moderator
Jul 22, 2024 12:07 PM UTC
Hello @元杨_10712694,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
